Will Not Start with Key Fob
adjustermm
St Augustine Florida
2024 Palisade
I have a 2024 Palisade Calligraphy. Last night we went to our son's house for dinner. We we got in the Palisade to go home, the car would not start. It was like the key fob battery was dead. I tried starting it with the remote and it started right up, but would stop running when you put it in gear. (like it is supposed to do). I tried starting it with the app on my phone and it started up just fine. I was able to put in gear and drive home with no issues. When I got home, I read everything I could find in the owners manual and online including this forum. I decided to give up and go to bed. I got up this morning and changed the battery in my remote which I was sure I didn't need to do because it worked to start the car remotely. I decided since everything on the car seems to controlled by computer, I would disconnect the negative battery cable. I remove it and left it off maybe 3 or 4 minutes. I reconnected it and the car worked as it is supposed to. My "reboot" solved the problem. I hope it doesn't happen again, but just in case, I think I'll carry a ratchet with a 10mm deep socket. The car is scheduled for it's 15,000 mile service on September 10th. We'll see what the service department says. If I get anything helpful from them I will post it. I hope this helps someone.
BooBoo
US
2021 Hyundai Palisade Calligraphy
#2
Thank you for posting. At least I know we aren't the only ones!
Mine is a 2021 Palisade Calligraphy, too. Three times it has decided not to start when I have the fob inside the vehicle, foot on brake and push the start button. Nothing happens at all. Last night, it was dark and there were no lights on anywhere. I decided maybe the clamp on the terminal may be loose so I opened the door to go check that and when I opened the door, everything lit up. I managed to get a picture of it rebooting and then telling me that the Vehicle is On. HA!
My other typical random weirdness is the automatic wipers will decide to make one swipe approximately a mile down the road when using the vehicle initially that day. It doesn't happen every time and isn't when it is a certain temperature or time of day.
